Retro fit rodding eye.
2 Dec 2015
Morning. An inspector has asked I fit a rodding access to new 110 waste pipe which runs from an upstairs bathroom.
I’ve purchased one of these (see below) and wonder the best place to attach.
Thanks.
Seems like a stupid request to fit on a home system. What is the actual risk of a blockage?
Just tell him you will fit one when you actually need to - the process is exactly the same - you cut in to the pipe!
Any access point must be fitted in a place where it can actually be used and rods used easily, not where it is easy to fit or looks good
Thanks.
You would normally incorporate a fitting like this as you build the stack...
I’m following a builder doing some snagging. The client wants it. Was going to fit it on top of the the horizontal run so it definitely won’t leak. Means you need a step ladder to access for rodding.
I fit these for access in soilstacks:
Andy
More for CCTV by the looks of it. I need rodding access.
You nor
Yes but the builder didn’t and I dont want to mess about with the already installed stack. Hence the retrofit.
I've had a similar issue. Council BC demanded it... tried to argue, but there was no way. They would not issue a compliance certificate without it, so builder fitted a boss connector at the bottom of the svp so its reachable w/out any ladders.
