RF Lighting said:Sounds OK, but personally I would feed the shed from the non RCD side of the house CU, and then in the shed have either a CU with an RCD main switch, or better still (but more expensive) RCBOs for the circuits which require RCD protection.
Can I just double check how many MCBs will supply your grid switch?
The cleats I'm not sure about size.
I would go the the wholesaler and ask for cleats for a 6.0mm² 3 core SWA.
securespark said:RF Lighting said:Sounds OK, but personally I would feed the shed from the non RCD side of the house CU, and then in the shed have either a CU with an RCD main switch, or better still (but more expensive) RCBOs for the circuits which require RCD protection.
mdbalson said:The way I am going to now rewire the shed is:
(Put the shed on the RCD CCU, for now & then move it over to the non-RCD side of the 9way Wylex split-load board am going to put in, to replace the old 6way MEM CCU with.)..................
securespark said:Sorry. Don't follow...
securespark said:So until you replace your CU, there will be an RCD in both the shed & the supply CU's?
Adam_151 said:Third pic down? why an inspection bend on the corner of the shed? wouldn't it just have been easier and neater to pull a 90 degree bend there?
Edit, I'd have probably have installed a radial instead of a ring, and taken the conduit in one side of the sockets and out the other instead of using tees
