- Joined
- 17 Nov 2020
- Messages
- 43
- Reaction score
- 0
- Country
chased capped and plastered over singles a while back then I hopped on here and asked for an opinion and was rightly cohrrected,that you cannot put singles in capping, that It needed to be in 20mm black conduit
I have got around to try and mend the problem and removed the plaster but am not sure about using the 20mm conduit on a single brick wall the length of which is 2.5 meter on one side then 4 meter on the other side finishing of with 1.5 meters,the plaster is not so deep that I can get away with just a bit of chase on the brick
So could I use oval conduit is there regulations against?
I did buy some oval to round adapters but am not sure how I would manage the conduit on a corner bend
It was also suggest that I could use some wagos three of them and fit them in the back box, that way I don't have to worry about the cables in the chase ( Using this method does seem like a good Idea but theres 2 red 2 black 2 neutral wires so how would I proceed to connect them to 2 T&E cables to four sockets.
On the other room I did manage to chase the black conduit but I hipt a snag in that on one side the conduit goes into the back box but on the other side it cannot as it does not seem to fit into an old single back box which was used to extend the sockets
Here's the photos
Thanks in advance
Cheers
Here's the photos
Thanks in advance
Cheers
