Six Days
You do know there are variations each year right?
"The National Oceanic and Atmospheric Administration (NOAA) has been monitoring the relative sea level -- the height of the water relative to the land -- at Fort Denison since 1886 (archived here).
Data through 2022 shows such levels have risen by about 0.03 inches (0.8 millimeters) per year on average, or a change of slightly above three inches (eight centimeters) over 100 years, according to the US agency.
A spokesperson for Australia's Bureau of Meteorology similarly told AFP that between 1914 and April 2025, the local annual mean sea level has increased.
"Just like other weather and ocean variables, some years have higher than average sea level while other years have lower than average sea levels," the spokesperson said June 16.
Multiple studies have also observed changes in Australia's sea levels over time (archived here and here).
"The reality is that the average global sea level is rising, and the sea level around Fort Denison is no exception," climate scientist Shaina Sadai told AFP June 13 (archived here).
There's also a YT vid on this I saw a number of years ago, but not in a situation where I can post that right now.
Yes I read the debunk post before I posted the photo. How does melting Arctic ice raise sea levels. And is the fort landmass sinking over 100 years or is the sea rising.
2C warmer you say
Lets look at what cop31 has said about 2C warmer
Almost exactly a decade ago a group of the world's climate scientists - the official UN body the IPCC - warned what would happen if temperatures rose 1.5C vs 2C:
Sea level rise would be 10cm higher
Meanwhile
Circled in Red was Kerry Packers old house . I drank tea with his Butler and house keeper.
Home and away with you each day!
Perhaps you could point to the IPCC report that says it does.
Ice sheets in Greenland and Antarctica are at risk when we increas the global mean temperature:
"Global mean sea level rise (GMSLR) is projected to be around 0.1 m (0.04 – 0.16 m) less by the end of the 21st century in a 1.5°C warmer world compared to a 2°C warmer world (medium confidence). Projected GMSLR for 1.5°C of global warming has an indicative range of 0.26 – 0.77m, relative to 1986–2005, (medium confidence). A smaller sea level rise could mean that up to 10.4 million fewer people (based on the 2010 global population and assuming no adaptation) would be exposed to the impacts of sea level rise globally in 2100 at 1.5°C compared to at 2°C. A slower rate of sea level rise enables greater opportunities for adaptation (medium confidence). There is high confidence that sea level rise will continue beyond 2100. Instabilities exist for both the Greenland and Antarctic ice sheets, which could result in multi-meter rises in sea level on time scales of century to millennia. There is (medium confidence) that these instabilities could be triggered at around 1.5°C to 2°C of global warming. {3.3.9, 3.4.5, 3.6.3} "
Oh, and the tidal gauges in that area of the fort show that the sea has risen on average, despite the land rising by about 0.3mm per year owing to the retreat of the ice sheet from the last ice age:
"For Sydney, one of the processes that cause a below-average rate of sea level is Glacial Isostatic Adjustment. During the last glacial cycle, large parts of the Earth were covered by thick ice sheets, often more than a kilometer thick. The solid Earth below these ice sheets deformed under this load. Eventually, these ice sheets have melted, but the Earth is still recovering from these loads, which still causes the Earth’s shape to change. For Sydney, this means that the Earth is lifting up by about 0.3 mm/yr[2], which could explain a part of the difference.
Long story short: from these pictures, one cannot conclude that sea level in Sydney has risen by 0.0 cm. In fact, two independent tide gauge records show that sea level in Sydney has risen by about 12 cm since the end of the 19th century."
I said Arctic ice and you gone off about Antarctic. :rolleyes: Also that's a lot of desperate debunking there. So basically the the fort does not show any seal level rise because the land mass is rising at the same level as the sea(y)
I'll repeat the question:
This was in response to:
"How does melting Arctic ice raise sea levels. "
Shaming language noted.
Read the post again. It says the sea has risen even at that point, despite the land mass rising as well.
Yes there is no mystery as why the sea in that area is warming, the Mid-Atlantic Ridge a tectonic plate boundary stretching over 16,000 km through the Atlantic Ocean where plates pull apart at roughly 2 to 2.5 cm per year. Over 90% of the ridge is submerged at an average depth of about 2,500 meters, with magma rising to create new seafloor.
And the area is getting hotter - and the cause -- the SUN
The link made no mention of the Atlantic. It was regarding global sea levels, and the main drivers behind it.
Perhaps read the link.
Plate tectonics and the sun have all been accounted for.
Unless you have a peer-reviewed study that says otherwise of course.
in my bath i turn on the hot tap the hot water doesn't stay down that end
The sea is being heated from below and that heating has been increasing and scientists found it to be hotter than they thought.
Deep mantle upwelling: Seismic research published in 2021 found hotter-than-expected temperatures in the mantle transition zone beneath the ridge,
The sun and space weather plays a part in seismic activity
Sunspots, and therefore solar activity, cause seismic activity, according to a team led by computer scientist Matheus Henrique Junqueira Saldanha of the University of Tsukuba in Japan.
What do you want people on this forum to do about it? You should be talking to China and India, who are building coal-fired power stations like there's no tomorrow (and there may not be!)
China is already the leading nation in Green tech., too.
Indians still worship cows.
