Yeah you need that looking at, for a start you have no earth to your fuseboard (you can see the DNO have provided you an earth terminal, but no one has run a cable between that and the fuse
You appear to have no main earthing conductor.
Ok, I'm a bit slow today lol.
That's standard... it's also feeding next door, so if you're away and they blow their main fuse...Bowness72 said:To my untrained eye that one looks even worse than mine.
Told you!I have already tried to identify the fuses/circuits and you will be surprised to hear they are far from what you would expect. Haven't quite got to the bottom of all of them yet though.
note that although many changes to electrics needs registered electricions or building control now (see part p in the wiki), anyone is alowed to upgrade the bonding -so your uncle may come in use here, or ask and the good folks here will guide you through to save a few bob and put it towards the CU etc!dingbat said:such as upgrading the bonding to your incoming services
Bowness72 said:I will probably get under the floor and take a couple of floor boards up and see what I can see.
