Striped carpet on a staircase turn
2 Jan 2007
Berkshire
Hi guy's
We're looking at a striped for our stairway. The carpet people said we need to be careful that when the turn happens the lines will drift.
Ok we understand that but how much will it drift?
we got a piece of paper and drew stripes and cut the paper in half and tried to 'see' how much the drift was.
We are not planning to do the fitting and shall be getting it done professionally but welcome advice if any fitters here have done such a thing
View media item 13739 View media item 13740
Cheers
Richard
an experienced fitter should be abe to line up the strips so that the stripes form an overall straight effect.
but find a decent carpet fitter well that's gonna be more difficult!
lay the ground rules before he starts
get it right or you don't get paid! be prepared to pay a little extra for the extra time he will need to fit properly.
You don't want a professional, you want a magician!
Cutting at an angle will leave the stripes wider at the angled cut than they are on a 90 degree cut. They will also drift out so you cannot line all the stripes up.
As the risers are cut at 90 degrees and the treads an angle each join will look odd.
Draw some 1" stripes on a piece of paper and try it!
correct! Its not possible to match on winders into straight stairs.
yep i fully agree with IJWS15
only 1 stripe can line up then they go progressivley out
the only way the strips can line up with the risers is if they go back at right angles so nothing lines up at the back off the treads on the winders
I'm currently facing a similar problem so any hints and tips would be appreciated.
Also, if you could post a picture of the finished look it would be great!
Cheers
i would suggest they didnt have it done and if they did i suspect the results would not be to pleasing :wink:
I had chosen exactly the same carpet - Brinton's Chocolate Fudge. Sadly I have exactly the same stairs as yours so can't have the stripe. Given that your taste is impeccable - what spotty carpet did you choose :?:
