Hi
About 3 years ago my Mum had a local electrician fit a PIR sensor to control her outside light. Last week, the light stopped coming on. I assumed it was the bulb and changed the bulb but that wasn't it. I've moved the sensor to test and still no light. I'm prepared to spend £30 on a new sensor, which appears to be this one: http://www.scldirect.co.uk/200-degree-professional-black-pir-1795.html
However, I don't want to spend the money and the time swapping the sensor over if that's not the problem. I know the bulbs are OK. Is there anything else that could fail, apart from the sensor? Is there a way of checking that the sensor is at fault?
Thanks in advance!
Thanks in advance!
