Things that make ya go hmmmm . . .
522 SELECTION AND ERECTION OF WIRING SYSTEMS IN RELATION TO EXTERNAL INFLUENCES
522.9 Presence of flora and/or mould growth (AK)
522.9.1 Where the conditions experienced or expected constitute a hazard (AK2), the wiring system shall be
selected accordingly or special protective measures shall be adopted.
NOTE 1: An installation method which facilitates the removal of such growths may be necessary (see Section 529).
NOTE 2: Possible preventive measures, are closed types of installation (conduit or channel). maintaining distances to plants an
regular cleaning of the relevant wiring system.
522.10 Presence of fauna (AL)
522.10.1 Where conditions experienced or expected constitute a hazard (AL2), the wiring system shall be
selected accordingly, or special protective measures shall be adopted, for example. by:
(i) the mechanical characteristics of the wiring system. or
(ii) the location selected. or
(iii) the provision of additional local or general protection against mechanical damage, or
(iv) any combination of the above.
From Part L
Fixed external lighting
Fixed external lighting means lighting fixed to an external surface of the dwelling supplied from the occupier's electrical system. It excludes the lighting in common areas in blocks of flats and other access-way lighting provided communally.
48 When providing fixed external lighting, reasonable provision should be made to enable effective control and/or the use of efficient lamps such that:
a. EITHER: Lamp capacity does not exceed 150 Watts per light fitting and the lighting automatically switches off:
i. When there is enough daylight; and
ii. When it is not required at night; or
b. the lighting fittings have sockets that can only be used with lamps having an efficacy greater than 40 lumens per circuit-Watt.
Compact fluorescent lamp types would meet the standard in (b), but GLS tungsten lamps with bayonet cap or Edison screw bases, or tungsten halogen lamps would not.
I think that covers it but he who is without sin should cast the first stone!
Providing it's 4mm² flex, it'll be OK.
Even if it stretches, it should still have an acceptable csa... :wink:
