Not sure it this is the best place to post this.
I have moved into a 10 year old and the bath seal is failing and leaking. I've tried a temporary fix of applying a thin bead of silicone not ideal but it's still leaking. I don't like these bath seals but I don't want to removed any tiles as the seal is fixed under the tiles. I was wondering if I could remove the section on seal you can see using a Stanley knife, leaving the bit still under the tile then silicone along the entire baths properly.
Has anyone done this or has a better option.
