Hi would any of you awesome people out there be able to give me a hand my programmer timer for the boiler has packed in and the read out is just staying same 12:21pm frozen and not allowing any control of the boiler so cant get heat. My brother inlaw dropped me in a sunvic select 107xl which I'm not sure is compatable but if theres a way I'll use it.
Old controller is a set2e which has never heated the water since the boiler was installed (new boiler furnace but same old crappy grubby controller) even though been told the heating always heated the water but boiler installer couldn't get it working although he saids "thats it all ready to go should have hot water and that heat over flow radiator in bathroom working" but never had heat and only if boiler is run at near full temp with pump on 3 does the bathroom rad heat.
Anyway nuff about that times are hard and money is non existant I'm more than able on most jobs and have stripped the boiler down and cleaned the entire system as rust and sludge had got through the system as the "boiler guy" didn't install a filter anywhere on the line from tank to nozzle so only filters on the system were oil pump, nozzle assemblys check valve (I know not a filter but it stopped a fair bit) and the nozzle itself all these have been cleaned and new nozzle ordered and a filter from the old system fitted at oil line into pump to catch any crap to stop the system bunging up as much as it did also cleaned the baffles and flue.
So heres what I have: boiler, timer and single pump
And heres what I want to wire it into
Boiler is a Worchester bosch 70/90-000-NI-L
Not sure if its even possible but if it is I don't mind as long as it works old timer is T45 and other is T35.
Thanks for any input
