Took double socket off wall and discovered 3x cables
Thanks for explaining, that sounds straight forward. I always wondered how they were used like that.
Before it's too late, the cables shown in the new socket on the left look very short, you need another two inches.
Hey spark, it's okay. I have loads of extra length on the right side of the photo. Thanks for making sure that was clear.
Yes, but it would look more complicated with all three lots of wires.
Not to mention the actual wires will not be nice curves and straight lines.
A tip - if you haven't already done it.
When all the wires are disconnected pull them straight out towards you straightened and untangled.
Then connect all the earth wires first nice and neatly, routing them as much as possible together, then push them to the back of the box, keeping them away from where the screws will go, allowing for the fact that the socket has to squash some of them a bit when positioned.
Then do the same with the neutrals, and then the Lives.
Hello there, I think I sussed it out.
It's annoying how they were buried just under the surface of the plaster and to remove the backbox I had to pull the cables free from the wall.
All sockets working except the conservatory and socket wired into what must be the spur circuitry?
Turns out the original backbox was really deep so there's at least a 2cm gap between the new backbox and the plaster.
Looking good.
I assume you have proved the 2 cables in the socket are the ring and it looks like one runs off to the left.
The joists run left to right.
Question:will that cable lift out through the gap and will it reach the other socket? If it will then you can do away with one of the horizontal cables and the connectors in the back of the socket. It will mean another vertical chase below the new socket but it will tidy the wiring:
Even better if one of the spurs will move too:
I don't think the wires in the socket are the ring, I think it's the other two cables.
The socket is dead at the moment.
I checked with the multimeter first and wasn't getting equal readings for all cables when fuses switched off.
I think the cables I have fed through the backbox are the ring as everything is getting power everywhere else.
I can't lift the floorboards and there is only slack on the left cable. The rest are tight.
I'm almost ready to fix the wiring but still a little unclear on this because Wacos only have a maximum of four holes and I'm now trying to introduce two more cables.
full
Just to confirm, if I am looping, it won't be wired like this will it? This to me implies two spurs (I am not very good at reading wiring diagrams).
You do have 2 spurs so the final arrangement can very well be like this with 4 wire in each wago.
Going back to EFLs simplified diagram showing only live wires [red and brown] there will be 4 wires in the wago, however if it's more convenient it could be done with only 3 or 2 wires:
