I'm in the process of buying a new bathroom and I want a towel radiator to go behind the bathroom door.
There's a 10cm space behind the door when open so the rad will fit fine but when I've gone to buy valves they stick out another 5cm+ and will hit the door.
Normal and angled valves are £20ish but the ones I really need are like this;
http://www.heatandplumb.com/acatalo...arch&utm_medium=GoogleBase&utm_campaign=Feed1
Why the hell are they £150?? Does anyone know of cheaper/similar products where the valve will basically be flush with the towel rad?
Last resort is copper pipe through the wall and then bent at 90degree angle leading to a straight valve.
Cheers
Cheers
