The two wires connected to a switch are not L&N and never were.No I meant L to N
Go argue with the IET.
No need. It is only you who doesn't understand.Go argue with the IET.
Because it makes no difference?Why do you think they still show standard wire being used for a light switch and not twin brown?
Stop arguing with them, then.The problem really is that electricians are trained.
Do you know what you meant?Once only in factories etc that employed them slowly but surely all need to be.
As I think you've been told, in some parts of the British Isles, twin brown (previously twin red) is seemingly the ('required') norm.Twin brown used elsewhere has it's interesting points because as soon as an electrician looks at that type of circuit they will know that it's not the usual type of light switch as soon as they take the switch off.
Other than for the CPC, I think that would probably still be compliant in the UK, but I'm not so sure about the rest of the British Isles.One DIY domestic electric installation was wired with purple singles of appropriate cross sectional area. CPC was green. Every wire had a wire number at both of its ends. It was at the time deemed compliant ( circa 1960 )
Generally I find most 2 way is wired with the red or brown in 'com' however I automatically try to make brown as perm live on a 3 core.Yes, if you use twin brown cable for the 'strappers' between two switches in a 2-way switching set up, then it doesn't make any difference which is which. However, as I said, in some other light switching situations you might need to know which of two browns in a 'switch drop' was the permanent live.
Kind Regards, John
And that sort of system is typical of the way control panels are currently built and to a lesser extent the field wiring too.One DIY domestic electric installation was wired with purple singles of appropriate cross sectional area. CPC was green.
Indeed, at the last house I did 3-gang switches in the bedrooms - and 2off T&E drops from a JB. So 4off brown cores - identified with cable markers as "L", "1", "2", and "3". Actually, as some of the existing cable was retained, 2xred and 2xbrown cores which saved a little bit of testing to identify them.Not necessarily both live all of the time. In the case of more complex light switching (with multi-gang switches), one might need to know which of a pair was the 'permanent live'.
Twin brown is a brilliant idea and brown and blue should be illegal for misuse as a switch drop without a neutral. You don't need three core for strappers.I don't like twin brown so never bought any.
If twin brown is such a brilliant idea (it's not), why don't they make triple brown for two-way lighting strappers?
You do if you want to minimise radiation of 50Hz.You don't need three core for strappers.
