8A at 13V is 104W so the motor will be a bit less than that - if it does drive the motor.
serves no value what so ever in this instanceI can’t get to it at present but looks like this.
as an aside the 300w will be unlikly to to be the average consumptionI don’t use the thing I just happen to have one.
I thought that somehow looking at the screen before and then switching on the machine might advise me but not by the seems of it.
300w is what I will take away from this.
Thanks.
You can't get mains rated cables under the size required for 120 watt, it is around ½ an amp. O.5 mm² is ample, on the 13 volt size the charger shows the current 0.8 amp so likely 1 mm². Your not really worried about what the motor uses, only what the charger takes or delivers.So I can then purchase the correct cable size for inverter.
So big question is why do you need to know wattage of motor?
