hi.
im trying to connect 2 wall lights side by side in living room
i want to do this via a 3amp (3pin plug) instead of using a FCU fused at 3amp.
i am familiar with the wiring as the light tiself has earth (metal linked) and blue / brown wires,
i will off course use a 3core black 1.5mm cable from the light to the 3amp 3pin plug.
the problem im having at moment how do i make sure both lights can come on together just by pressing the 3amp 3 pin plug??
ie how do i wire the lights up so when i switch on the 3amp plug both lights will light up??
thanks
thanks
