"I don't see how using 6mm cable to supply the socket instead of 2.5mm can make any difference to the sound quality. "
The general belief is that its down mainly down to impedence.
And mains wiring does effect sound quality in proper hifi systems (not cheaper -£1000 stuff).
I have used my system just plugged into an extention lead instead of the wall socket and the sound got worse.If your not into or dont have experience of hi quality hifi it will be hard to understand this and what the differences are.But they are not imagination.
Every extra connection on the line causes problems, and this is in line with physics.Electricity runs in a circuit.Any point in the circuit can effect the entire flow in the whole circuit.Having high impedence points on your mains effects the operation of the connected equipment.
This is not a issue on most household items as most are not sensitive measuring devices, but the way amplifiers work and loudspeakers are as measuring work is a direct reflection of mains quality.
Now shoot me down in flames.
[/i]
