But, if you would like to explain how they DO, then I'm up for a laugh.
How is a Heatmiser Touch V2 not compliant? Think now Dannyboy. It is best you reply "I don't really know". Stop making things up.And yet you recommend a programmable room stat (which is non compliant in this instance) with an integral timer (which is even more non compliant).
Fook me you are an embarrassment.
The only thing you can blind is yourself with all that "scratching" you do.
It's only ErP Class 1 as a standalone unit. Minimum requirement for new installations is ErP Class IVHow is a Heatmiser Touch V2 not compliant? Think now Dannyboy. It is best you reply "I don't really know". Stop making things up.
What's your point
offering installers a business opportunity to sell controls
That will give them compensated and modulating control over the boiler so fully boiler plus compliant and much cheaper than a heat miser
Heatmiser Touch V2:
ErP Class & Ratings
Multi Room Control with Individual Boiler Interlock
I (1%) Class VIII (5%)
The OpenTherm protocol enables the burner to be modulated to the dictates of the room temperature sensor. However, few boilers provide the OpenTherm protocol. In a 2 bed flat this function offers not much at all. Many boilers drop the flow temperature to the dictates of the return pipe temperature anyhow. They monitor the flow and return and know when the house is near to temperature modulating down. The room stat just does the final switch off when setpoint is reached.Over complicated and over priced control "systems" can be a significant profit generator while providing little if any benefit to the home owner.
Fantastic! Dannyboy came in. Look at the extras that can be fitted to the Touch V2.Dumbass
What's complicated about a system that needs a boiler and a thermostat that connects directly to it by RF so no wiring, boxes on the wall or anything
For combi boilers energy saving controls are not optional....
I just specified a Heatmiser Touch V2 with a combi with OpenTherm. Why? Because the Touch V2 is easy to use when set to thermostat only mode (they have the choice of using the timeclock on the combi or in the Touch V2). And, they have underfloor electric heating in the bathroom controlled by a Heatmiser neo Stat-e. The two stats/timers are similar to operate for the user. The user then does not have to get their heads around how two thermostats work.
