Launter, sorry to carry this on,
I have 3 degrees and Daddy bought me a pony
here is a lot of good advice on this forum from the pros and a lot of common sense talked by well meaning amateurs. The trick is to get things in proportion
fetty said:Would it be better to extend the spur socket and fit a double socket near appliances (running cable along skirting) or run a double extention cable from fridge & freezer to single socket in cupboard?
fetty said:I've had an electrician out and it's going to cost loads as my water pipes are not earthed, so is plugging an extension in for both appliances a better option?
The law will catch up, Part P and the HIP requirements are a marriage that will allow a potential new owner to insist that the required paperwork is in place for declared improvements.
Taylortwocities said:I can't belive it, Mr Balenza lights blue touch paper and has retired from the scene.
Cool it guys, I wonder how the OP is getting on??
Balenza said:I am conseeeedrabily reeecher that most on here
Chri5 said:You've been told.........![]()
Securespark wrote
To go back to your argument, you are missing the point entirely.
We don't always say "get an electrician". Only when it is painfully obvious the posters do not possess the knowledge to carry out a safe job
insecure?
To be picky, the CORGI rules apply only to CORGI members - in no circumstances do they apply to DIYers.ColJack said:I don't expect a gas fitter to tell me how to do something that I'm not able to do and ignore the CORGI rules.
The latter certainly isn't a true statement, so does this remove the basis for you believing that all DIY electrical work should be illegal?I personally think that all domestic electrical work should be made illegal unless done by a qualified and registered electrician.. same as gas can only be done by CORGI registered plumbers.
Like hell it will.![]()
Why ? Because my home will never have any potential new owners and when it does I will be dead and gone. (If it aint burnt down before that and if it is I shall just build a new one as I am conseeeedrabily reeecher that most on here)
Unless the current dictatorship we are living under at present decide to implement further legislation than will infinge my human rights regarding doing what I want, when I want in my own home.
So you lot can go shove your regs where the sun dont shine.![]()
As for HIPs, well, the home condition report was dropped a year ago.
this is starting to get a little boring.Part P, Part P. HIP, HIP, HIP
Same applies to housing, so when they decide to build a new treatment works (for all the excrement you write) adjacent to your property don't be surprised if a keen buyer asks for warranty and test / cert paperwork for all the work you've done.
