has any one else noticed how rubbish Wylex cus are becoming latley. As i bought a 8 way insulated RCD cu the other day, but when i opened it to check it, i found that with the breakers to be able to put the cover on you have have the breaker up higher to have it level with the rcd, but in doing so it means the breaker does hook on to the rail at the top of the cu tray as it should, so this means that ownly the busbar is holding the breaker in, and also the busbar is not level either so the breakers at the end of the cu will ownly just be touching the busbar.
So that cu is going back and i will be getting a different brand.
Here are some pictures of what i was saying about
The MCB in place:
The MCB in place:
