your worst boilers to work on
25 Dec 2007
just wondering what you guys consider to be some of the worst boiler to work on are. my list goes a little something like this:
all saunier duval hate the lot of em i gladly turn away saunier duval
worcester bosch 26 CDi extra (what the hell was they thinking when they made this boiler. everything is hard to get to and to change the heat box you have to strip everything out of the boiler never again) :shock:
worcester bosch 24CDi i never did understand why this boiler gets soo much happy talk its not as good as people make out then again once youve done a few there not to bad to work on
all chaffoteaux et Maury (eehh!!!!)
anyway thats my lot
sd must be number one
heatlines are a nightmare because they are always installed by Cowboy de Luxe, dogy controls, lethal electrics, undersized and botched pipe and so on
ravenheat partially because they are also cowboy prone and the multiple boards can be an issue and a 200plus quid a set, you don't want to take risks
yeah the amount of times ive been called out to ravenheat boilers and the customer has taken the combustion chamber of them selves!!!! :shock: :shock:
i find the casing system on them pretty **** cant understand why they need to make the combustion cover so fidly so for that reason yeah dont like em on the plus side though if the case is not on properly the pressure switch wont make
The chaffoteaux celtic,with the expansin vessel on the front,so if your working high up,its a nightmare as its awkward and not very light.I hate them and old ariston were you had to take the boile off the wall to replace at least 3 parts. I dont rae the worcester greenstar he system boilrs,the fan you need to take the gas pipe out and its a right pain
The only boiler which I will not repair is the Sonya Duval becase it leaks everywhere.
If I am not busy then I will cover combustion related problems but NEVER leaks!!!
All other boilers I will repair!
cor woaahh ive got some jobs for you then in the future my freind :shock: :shock:
Why gas? You always seem to mention them as the alternate choice to Vaillant.
ANYTHING that has had a blinking cupboard built round it.
Hmmm Perhaps I'm odd...I like the Greenstars
Just because I think of them as a main stream alternative to Vaillant, although I wouldn't fit one, doesn't mean I know how to fix them :shock:
Admittedly I was referring mainly to the older ones and have only been out to 1 new Greenstar, but this took me 3 times as long to fix as I had to read all th MI's first to know how to set it up :oops:
Turned out it was an LPG version that had LPG stickers all over it but for some reason was set running as NG :?
Nearly blew my FGA off the CO scale :lol:
Older worcesters, I find were never designed to be worked on easily and the few I have done took ages to stop leaking afterwards, hence I don't offer repairs anymore, just basic servicing.
