A
attractivebrunette
I can't think of any time ever that I would have both oven and all 4 rings of the hob working. The most would be oven and two rings.
Saw one on here the other day, just a standard outlet plate, with a socket spurred off it, on a dual box. looked ok. Not sure about whether its specced for it though.Steve: Are you sure that outlet plate is spec'd to take 2 load cables? I don't know the beast myself. If not, this one is.
TROLL
TROLL
Anyone in particular?
And thank you for all the PM's of support.
even if it is a troll, there is a lot of good information comming out and it might help someone in a similar situation..
...So how easy is it to do? Do I need to disconect the whole gas supply first or do I just make sure the hob gas rings aren't turned to 'on'?
attractivebrunette wrote:
But how do I 'tap in' to a nearby electricity point? Is it called creating a spur or something?
NoNoNoNoNo!
Apart from miniature one-ringers used in caravans and bedsits, an electric hob takes a large current and CANNOT be supplied from a socket, or from tapping into a socket circuit.
It needs a dedicated cooker supply circuit, with a 32A or higher MCB and 6mm or bigger cable, and big switch and outlet.
If you do not already have a cooker circuit, start saving up for a professional job, or get a nice gas hob (which is quicker to heat, more controllable, safer, and cheaper to run)
Hob 6.4kw = 27.8 AMPS
2. So I decided to use a cable rated at 3A for it.
Curiosity over whether the realisation of her limitations will ever dawn on her?Out of interest, has anyone noticed the number of views of this post? Morbid fascination, genuine concern, or what?
Maybe it has..I'm not going to switch anything on at all, unless I and everyone else is 100% sure there are no problems. If that means getting in an electrician, that's what I'll do.
All trolls are liars - it's what they do.You are a liar, and I suspect a quite convincing troll.
Reason a) They are stupid.Unfortunately, there are those people who, for whatever reasons, completely ignore what they are told and do something else instead.
Still don't think she is stupid?...So how easy is it to do? Do I need to disconect the whole gas supply first or do I just make sure the hob gas rings aren't turned to 'on'?
oh boy....![]()
