RCD before CU
  • Thread starter Thread starter ColinJacobson
  • Start date Start date
That's fair comment regards the cable size, but I'd say 8 out of 10 of my mates would install 1.5.
If you were looping through the switch boxes you would use 1.00mm ;)
No I wouldn't. I'd use a wago to connect the 1.5 neutrals. Also, from reading your posts, you appear to have butchered a circuit because you didn't understand it. Have I missed something here? Was there a problem with the original switch?
Also, the table you referred to should only be used as a guide. I would suggest you read up on cable calcs.
I fully understand it OK! There were too many cables in the box, with too many 1.5mm wires and terminal blocks.
I have used a wago. I looked them up and can't see where they would help.
I did ask if there was a problem with the switch.
wagos are tiny and you push fit the conductors.
Meh, lever is nicer.
agreed, but when space is tight, the push fit comes in useful.
either is better than a connector block.
Can the wires be pulled back out?
Yes, you twist them to remove. Or use the lever type, which just require a fingernail sacrifice.
