Hi to all this is my first post on this forum although I have been a bit of a lurker until now
My question.. The lights in my living room have not worked for few years now although they used to before i moved in, apparently they stopped when the dimmer switch got knocked and broke one day.
I fitted a new switch the day i moved in but the lights still didn't work so not knowing what i was doing I've left them alone until tonight;
Behind the switch is two red wires. Using one of them 'light up' screwdrivers I found one to be permanent so i put this on the common of the dimmer and the other in L1, then i tested the switched wire and that lights up and goes off when you press the switch. Working yes?
So now i went up to the spotlight (one of two), unclipped it and found the terminals, the red wire does indeed llight up when i turn on the dimmer switch but not as bright as it does when i test it at the switch. No matter where the dimmer control was.
And the light bulbs are brand new !!
Any help would be so appreciated we need lights in our living room!
