Not sure what is unlaw full.http://www.bbc.co.uk/iplayer/episode/b0161pg0/Dirty_Tricks_of_the_Tradesmen_Episode_9/
29.30 just wonering if that would be against the law
sshhh just rember to bend right this time a 90 not a 45just a quicky
OK hun, but not here, everyone's looking.
Meet you round the back in 5.![]()
he working inside the consumer unit
Going on what I have seen of the video, which is around the 29-32 min. I have not seen him do anything illegal. There is no law preventing him from testing the RCD. Providing he does not make the installation unsafe.he working inside the consumer unit
Righto!![]()
Indeed not - in fact Part P is not an approved document and does not refer to one.I am not going to bicker over trivialities over part p, part p is just not about a paragraph in an approved document.Stuff
Part P is not about compliance - it does not describe anything to do with compliance - it is a requirement.It's about compliance.
But in saying you don't need one you accept the notion that one exists - don't you see that?I never said there was a qualification, I said you didn't need one!
That link did not disprove it - that link was to a site which is wrong.Well you said there was no such thing as one and I offered you a link to disprove that, whether they understand English or not.
You don't actually have any grasp of what that programme is about, or what they do in it, do you?no worries, just wondering they broke gas safty regs earlyier in the show.
he fixs gas leak and etheir does a tightness test or does something worse
just turns the gas on. I reality what they should done is turn gas off and ring trasco
Yes, but ...just a quicky can you fit a consumer unit with out part p and be member of registered body?
As already pointed out, just because it's inside a consumer unit doesn't automatically make it notifiable work. Replacing fittings is expressly allowed, as is replacing single cables and protective devices. So it's perfectly legal to replace (eg) a failed RCD with another of the same characteristics.this not for me, it about rather anouying tv programme called dirty tricks of the trade
True, but (without going and looking it up again), there's mention in places along the lines of "as long as protective measures aren't affected". If you fitted an RCD of different characteristics, then there's a question as to whether the protective measures are affected (not adversely IMO if it's faster/more sensitive) - so if you don't have the knowledge/skills to do the assessment then it's simpler to stick to like-for-like even if a strict interpretation doesn't require it. But since it's not easy (as in someone who doesn't know what they are doing is unlikely to find one by accident) to find anything but a 30mA/30ms RCD then it's a fairly moot point.Replacing fittings is expressly allowed, as is replacing single cables and protective devices. So it's perfectly legal to replace (eg) a failed RCD with another of the same characteristics.
There's nothing which specifically restricts the replacement to being one of the same characteristics even.
