Just bought a house and had it rewired, what was in there was just horrific but I won't bore you with the detail.
Anyway, paid for a full rewire of the sockets to put in 2 new ring mains, and a partial rewire of the lighting circuit (check for safety, reuse cable if fine) and to have old fuseboards replaced with with a modern consumer unit as well as a couple of other bits and bobs (removing dodgy rig to garage, removing redundant immersion switch left loose, loosely wired in what used to be the kid's bedroom(!)).
Would appreciate views on:
Should the old socket cable have been completely ripped out? I had assumed yes but have found instances where it has just been cut back and left buried in the wall
I have concerns about how safely wired one of the light switches is, got an admittedly cheap mains voltage tester pen that suggests potential on the faceplate and the wiring looks a mess - this should have been checked right?
Old junction boxes, one held together with wire remain under the floorboards on the landing, at least one of them is still carrying power - should these have been replaced, and I read somewhere that regulations now do not allow for any screwed connections to be hidden, is that right?
I haven't paid the guy yet because of these outstanding concerns (they were meant to finish last friday but I kept having to point out bits they hadn't finished, which in fairness they did then do without grumbling, but still....) - and they haven't yet given me a safety certificate which they promised to do in the quote, its absence is also making me suspicious.
I'm paranoid about electrical stuff so might be overworrying this, but would appreciate any opinions.
