Anyone care to repeat this, guess my trailing socket and/or plug must be defective. Not that much force was applied. Socket has got PMS 9128 written on it, plug has PMS 9248 written on it if any help for identifying the brands.
but you can't protect against bloody idiots.
Do they not have to conform to BS 1363?it seems there is no rule to require trailing sockets not to allow plug to be put in backwards.
They certainly usually come with BS1363 markings.Do they not have to conform to BS 1363?it seems there is no rule to require trailing sockets not to allow plug to be put in backwards.
Eveares - if you go to Fatally Flawed's website they've got links to a "sister" organisation which looks at things like this - you might as well report it to them.
Indeed not - but it supports/confirms our belief that it is required to comply with BS1363 (which it presumably doesn't).There is a BS1363/A marking on it as expected, but a marking does not guarantee that it conforms to it.
It doesn't appear to be only an old phenomenon. This is one (BS1363 marked) that 'er indoors bought from Homebase relatively recently (even though it's acquired a fair bit of 'cellar grime' since then!):....but I doubt it's worth reporting - The trailing socket is over 11 years old and has had a fair bit of use over the years.
Yes, I realise that. I should have made it clear that I was illustrating that the more common (and potentially more dangerous) issue is still around. With the Homebase one, in terms of 'fitting', I can do the same, but only after poking something into the earth pin hole to open the shutters:That's the other way round - video shows the L&N pins being inserted without the earth pin, resulting in the appliance being connected with reverse polarity (which almost certainly doesn't matter) and no earth connection at all.
On their home page there is a link to here: http://www.fatallyflawed.org.uk/html/links_to_safety_sites.htmlCould not find the like to the "sister" organisation , but I doubt it's worth reporting - The trailing socket is over 11 years old and has had a fair bit of use over the years.
And when they're just the integral switches in an appliance, far too much fuss is made about this possibility. Years ago many appliances which didn't need an earth and had S.P. switches were used with reversible 2-pin plugs. Many modern appliances in the U.K. are sold in the same basic form across Europe where they are still used with reversible plugs, so there's no way of guaranteeing which side of the supply a single-pole switch will end up in. In some places the appliance may even be used across two phases of a 127/220V system so whichever way it's connected it won't make any difference. It really doesn't matter anywhere near as much as some people have been led to believe.Expect that you will now have single pole switches on the Neutral side
