we are all human and make mistakes, this one being very easy to do.
So the real risk from leaving that cap off is very low UNLESS the boiler is not correctly set up as will be done at a service.
In some people it has an intoxicating effect and this can lead them into irrational and/or hazardous behaviour.At low concentrations, gaseous carbon dioxide appears to have little toxicological effect. At higher concentrations it leads to an increased respiratory rate, tachycardia, cardiac arrhythmias and impaired consciousness. Concentrations >10% may cause convulsions, coma and death.
What would your reaction be if a car mechanic left your car in a dangerous state due to being distracted by a phone call ?Your views are what internet forums are full of. Alternate thinker my ar5e.
In the 1970's I was allowed to work on the control systems of industrial gas heaters. I learnt a great deal from the experienced gas engineers that maintained the combustion equipment in those heaters. My remit included the safety systems that detected mal functions in the combustion system.. You are also not, as far as I can tell from ther posts that are way wide of the mark, qualified to have an opinion of any merit or gravitas in this area.
Maybe that is because there have been very few cases of an incompetant technician forgetting to replace the cap.To the best of my knowledge this isnt the case with a domestic flue sampling point.
This!! Amount of times I've phoned a Cust to go back to "collect serial number" in fact double check test point at gas valve ( all been ok) as you trick yourself into thinking "did I do that, I can't remember it?Maybe that is because there have been very few cases of an incompetant technician forgetting to replace the cap.
I have never heard of a decent gasman who has never ever gone back to a property to check a cap they can't remember refitting. I've done it a good few times, never found one missing but I'd never be arrogant enough to say I have never forgotten one.
Even kwikfit get a second engineer to check the wheel nuts torque after a wheel change.I wonder if I can remember to tighten the wheel nuts on this trailer I'm repairing?
John![]()
You're not a friend of John Harrison or Walter Systems by any chance are you?In the 1970's I was allowed to work on the control systems of industrial gas heaters. I learnt a great deal from the experienced gas engineers that maintained the combustion equipment in those heaters. My remit included the safety systems that detected mal functions in the combustion system.. You are also not, as far as I can tell from ther posts that are way wide of the mark, qualified to have an opinion of any merit or gravitas in this area.
