Dan, I have an engineering background and a university degree
So do I. Your blue Peter badge is in the post.
3033 customers on the active database
and the assessments carried out by academics over the past decades make interesting reading. Pity they are not in the public domain.Anyone with an engineering background can assess them well with a bit of reading of specs
That originally ran on town gas, converted to natural gas in the 1970s. Domestic? I must have costed a fortune to run. I recall domestic boilers that had no electrics in the controls. They had a relay valve that modulated the burner to a bead up to full rate all using gas weep pipes to wall thermostat and boiler stat. A pilot light of course. We have gone backwards in many respects.Oldest boiler we had was a Ideal Domestic #3 circa 1945. Now relocated to an Ideal training centre and replaced with an Intergas (obvs).
What type of back end protection did/does this boiler utilise?I saw an Ideal Concord about a year back in a house. It was heating a `large` thermal store with two thermostats, so it only came on once a day normally, and maybe twice in deep winter.
If I recall rightly It had a wax type blending valve, probably a Danfos. It probably is still chugging away. It came on in one cycle, burned up continuously without a cycle, and the thermal store cut it out. The controls, apart from thermocouples were all original. I suspected the boiler thermostat was kaput being so old, however the thermal store thermostats controlled the boiler so it never got to boiling point. Such a simple setup. The only complexity was that it had a summer/winter stat on the thermal store switched in and out by the user and a latching relay in a plastic electrical box. In summer it only heated the top half. Everything was original and it must have been from the late 1970s to early 1980s. Every now and then they had the hot water coil in the thermal store cylinder de-scaled.What type of back end protection did/does this boiler utilise?
Soft copper tube about 6mm. They were called `weep pipes` by some, I kid you not. Two copper pipes would be in the wall to the wall thermostat. You obviously think it is funny as it is all before your time."gas weep pipes"???....@ least try to google the correct terminology when referring to gas controls...
I recall the Chaffataeux that was like a multi-point. The external pump would lift the diaphragm and bring in the gas burner. But it needed an electric pump controlled from a room thermostat. The boilers I am on about were in the basement and heated the house or pub above by large bore pipe on gravity with no electrics whatsoever. I saw some in the flats in a block that had electric pumps.domestic gas heating boilers that did not require electrics were still available in the 80's ,late 80's if I recall ?may even have been the early 90's
Thermocouples?...so what action did you take regarding the "kaput" boiler stat??If I recall rightly It had a wax type blending valve. It probably is still chugging away. It came on in one cycle burned up, and the thermal store cut it out. The controls, apart from thermocouples was all original. I suspected the boiler thermostat was kaput, however the thermal store thermostats controlled the boiler so it never got to boiling point.
I was only looking at it, intrigued. I 'suspected' the boiler thermostat was kaput being so old. I never tested it. I never touched anything. I think they said they did replace one probe cylinder thermostat once. So thermocouples and one thermostat can't be bad for about 40 years. The blending valve was set to 55C.Thermocouples?...so what action did you take regarding the "kaput" boiler stat??
3 port blending valve?....@ what temperature did the "blending valve" port open to thermal store?
Hopefully I've got this right...so the high/low stats fitted to thermal store being the sole control for burner on/off???
