- Joined
- 11 Jan 2004
- Messages
- 46,765
- Reaction score
- 3,940
- Country
That depends upon where the cables to be replaced go to.
It's always best if you can, but of course you often can't.Ban
You seem to have a thing about replacing cables to avoid joints.
I'm sure you must realise that in the real world this is often not practical.
Not really, conduit is closed-jointed so conductors have to be drawn in from the ends, trunking has a removable lid, capping is just capping, not a type of cable duct.
conduit
part of a closed wiring system of circular or non-circular cross-section for insulated conductors and/or cables in electrical installations
Note 1 to entry: Conduits should be sufficiently close-jointed so that the insulated conductors and/or cables can only be drawn in and not inserted laterally.
Imagine you have a socket currently fed via two legs of a ring final.
It could be extended by running a further two legs to the new position from the existing one, then connecting one of the new legs to one of the existing legs. Thus by connecting one socket at each position to the two remaining legs at each point, the extended ring final is completed.
This isn't about extending cables by joining lengths on, it's about why do you have to end up with 4 cables where there's currently 2.
Then join/extend the cables from somewhere else, surely?BAS, there is a door in the way, he can't go horizontally, the two new legs will go back up in the oval conduit, with the original 2.
in one piece of conduit?
Regarding the washing machine socket... the two legs of the ring will go to the 20A DP switch... the socket will be about a meter below this switch. Because I've never worked on switch-less sockets before, do I take 2 more cables out from the DP switch down to the socket or is it OK to just have one (maybe a 4mm cable) between the DP switch and switch-less socket? Thanks.
