CO boiler shut off unit
Status
Not open for further replies.
Maggie Thatcher was the best PM this country has had
This proves your mind is not stable and that you should not be doing gas work. A stable mind is needed at all times when undertaking gas work, not a weak and wobbly one. You have failed on this point. I am sure you are a danger to the public.
Which is it? Plumber or heating engineer? They are different professions with different education, etc.
Oi lads, we're a profession now!!
That's great hard-on, we can charge like a Rhino now! Oops hold on, we do that already!!
Article was yonks ago and also referred to a Keston which has separate exhaust and intake pipes which are not in a concentric flue arrangement.
seen some of hard-**** previous threads and he has confirmed yet again he aint got a ****ing clue,just a google warrior
R&R, he's got some rep here, which is why the regulars ignored his initial post... I did consider warning you when I saw that you'd replied :unsure:
Heating engineers can design forced air, vent, etc. I am sure that is way out of your range. So you are not a heating engineer. Anyway what is your solution to the flue problem I gave?
I do believe a Keston has two pipes. So if you have no joins in a concentric flue pipe you are OK? No hatches?
Heating engineers can design forced air, vent, etc. I am sure that is way out of your range. Anyway what is your solution the problem I gave?
Their solution would be "Are you a gas safe engineer to ask a question in the first place" and get some hatches built, FFS if this was the way we would have more hatches in the tallest buyildings in London than windows!
Status
