they were really after 23's, 123's, usually £150. 45's like rocking horse poo.they've tried ebay? I saw some follow-spots much less. Travel can be an inconvenience.
Do they give a clue as to which regulation(s) they believe it contravenes?
No, nothing at all - I wonder if they know. I can't see any reason why it doesn't comply.
That's not a good thing.It was used in many theatres around here
If you think T&E is designed for non-domestic applications then you are as deluded as I already know you to be.Please refer to the regulation(s) that says that.
What I stated is correct.Not correct, T&E is adequately acceptable for such purposes, in fact I have a school job lined up for the Christmas break which has been spec'd as 1.5 T&E in cable basket. This is for 15A sockets on dimmer packs with 13A C type MCB's.
There is no British Standard for SY - it is VDE cable. SY, CY and YY cables are not generally considered compliant for mains voltage installations to BS 7671.Do they give a clue as to which regulation(s) they believe it contravenes?
T&E in non-domestic applications is, frankly, crap.
T&E in non-domestic applications is, frankly, crap. Where high fault currents exist, it may also be completely unsuitable.
Any good school spec is for galvanised trunking/conduit with LS0H singles (6491B). T&E in schools is complete rubbish and should never be specified that way.
Have you verified that the 1mm^2 cpc will be adequately protected by your C curve circuit breakers?
When poorly installed by idiotsMore accurately:
T&Ein non-domestic applicationsis, frankly, crap.
I don't disagree!More accurately:
I assume from that statement you have only ever worked in one school and that was a private school.I have only ever seen T+E in a private school !
DS
In a nutshell No!Have you verified that the 1mm^2 cpc will be adequately protected by your C curve circuit breakers?
Which contains a 1mm^2 cpc...It's 1.5mm², if I wrote 1mm² it's my error.
