Three equivalent ways of saying that areSo, I'd like to....
- "Because of that I'd like to...."
- "As a result I'd like to...."
- "Therefore I'd like to...."
Please think about why you should start a sentence with "So...."
Yes, but why??swap my existing 2 gang light switch in the lounge (which operates wall lights and central light) to a wifi smart light switch that does the same.
You'll need to put one of the blues into the switch, along with a wire from there to the connector block.I think if you look at the pictures that I have neutral wires that are capped at the back of the backbox. Therefore, I was thinking (but would welcome knowing if this is right), that I run a neutral cable from 'N' on the new switch back up into the collection of capped neutral wires at the back of the back box (or do all those neutral wires do different things?). I then take away the little cable that joins the 2 holes marked 'Common' on the old switch. The 2 wires which are left in the 'Common' holes on the old switch both go into 'L' on the new switch and the remaining 2 brown wires in holes marked '1 way' on the old switch go into L1 and L2 respectively.....
