Pass through socket or simple clamp showing power being used
11 Jul 2015
hi
I have a tumble dryer in an external shed running off a cable. It’s temp as having house gutted. Anyway, when it stops I have no way of knowing. Is there some indicator I can attach house side to tell me when it’s finished?
If it is plugged in to a socket in the house, then a cheapo plug-in 'energy monitor' (which is 'pass through') will tell you if it is drawing any current.
Ok ... who sells them and what price?
Don't all tumble-driers have a built in timer?
My mum's, which I inherited, had a simple clockwork type thing in the 70's
My washer drier has a push button that adds time in units. Just lok at your watch when you turn it on.
Er.... 20 mins after you set the timer for 20 mins?
Well, ours usually runs for 60 or 90 minutes but, yes, a watch/clock and a slight bit of memory ought to do the trick. I was not 'sympathising' with the OP's request, but was merely stating what he had asked!
I do the same, put a battery on charge using energy monitor, it goes through stages 3.8A, 3A, 0.8A 0.1A and off which show on energy monitor as 54W, 44W, 14W, 2W and nearly zero so in my case with a wifi internet connected model I can see where every I am as long as 3G signal what stage battery charger has reached.
With tumble drier you will get around 2kW then around 250W when in cooling stage then zero once complete. With a humidity sensor clearly time varies so yes would work OK.
I also use mine to test fridge/freezer from time to time, a little maths involved, but over a week it records time and power used, so divide power by hours and times by 8760 (hours in a year) and we have watt/hours per year divide by 1000 and kWh per year, if some where near what adverts say it should use OK, if well over then further tests is temperature set correctly or has insulation failed.
It is about the only use for the devices, as does not matter how much my TV uses I am still watching TV and anyway written on the plate.
