I had electrician coming to do a kitchen rewire as well as some other bits like moving switches, adding sockets in some rooms...etc.
I am now concerned if the first fix they've done was a bodge job after learning & reading a lot about renovation from many resources.
1. Wago connectors are left in the zone without enclosure, either under capping, behind stub & plasterboard, or buried under plaster.
2. 25mm back boxes used for USB socket plates (instruction says 35mm back backs should be used)
3. No CPC where new lighting is installed (although current lighting circuit has no CPC).
4. Although some area has oval conduit or capping, some just have penny washer and screws to hold the cable on bare brick and to be plastered on.
5. There will be cables underneath base unit behind kickboard in kitchen, not clipped on the wall.
6. Part of cables feeding kitchen are places in the boxed up conduit (20cm x 20cm) where the communal radiator pipes are.
I would really appreciate if I can get some opinion whether I should be worried and not have them coming back for remaining jobs. Thanks.
