- Joined
- 11 Jan 2004
- Messages
- 46,518
- Reaction score
- 3,819
- Country
All this talk of tops and bottoms is getting me quite excited....with every top you get a free bottom......
Washing machine often on wheels
remember the hot and cold feeds ?)
Am I really the only one that remembers green, purple and orange fuses? I don't remember the rating other than orange = 10A, Strand Junior 8 fuses will be engraved on my brain forever.I don't think you folks are paying enough attention...
They may be now but I think that was not always the case. I recall the card on the side of the 'plug rack' in the hardware shop with every size of plug and fuse on display with the maximum load in Amps, Watts and HP. I recall the 5A being 1 6/10 HP and asking my father what it meant.That's because only 3A and 13A are standard (or preferred) ratings.
This may be so according to the regs but MI's will often state the size of the plugs fuse as part of the appliance protection and that should be considered when performing a PAT as it may be different to the expected fuse.As you know the fuse is to protect the cable not what is on the end of it.
No, you're not alone in those memories; in fact, I think that I probably still have some in those colours! However, they don't appear to be mentioned in the 'current' version of BS 1362 - but (unless I'm missing something) that 'current' version appears to date from 1973, so maybe we are both giving away our ages!Am I really the only one that remembers green, purple and orange fuses? I don't remember the rating other than orange = 10A, Strand Junior 8 fuses will be engraved on my brain forever.
[QUOTE="SUNRAY, post: 4452298, member: 124249
If the MI states a certain size of fuse, using anything else could invalidate any warranty and possibly be the cause of a much bigger problem.
Still to this day dont understand HP
On oh so many occassions I've encountered the MI require a 7A fuse for a 1.5KW appliance on 0.75mm² flex (for example) with no additional protection built in and of course the plug will contain a fuse big enough to power 2 of them.
Many of the people I work with use the words Pat, Patted, Patting etc without the followinng 'testing'.
I during my apprenticeship had to test motors, at that time no direct read out of watts or horse power, we had the torque and the speed (revs) and we had to work it out and produce a graph for home work, 2πNT/33,000 is ingrained in my memory, seem to remember approx 750 watts in a horse power, but that was days of imperial so today not sure how it is worked out? I worked with poundals, pounds and slugs seem to remember times 32 for each, something to do with gravity, but now we have metric system so every thing times 10³ so there are 980 Oh where is the 10³ in that, or 1024 that's also not 10³ oh I give up, glad I have retired.Still to this day dont understand HP
