I don't believe that is what the OSG is talking about in the bit I quoted - that is surely talking about the number of (fused or unfused) spurs (i.e. cables branching off from the ring), not the number of things that can be supplied by each of those spurs/branches?Surely there referring to the drawing in appendix 15, and there "Fused" is referring to unlimited if the fuse is in the first spurred point or "unfused" as in spurred direct of the ring, they must not exceed the total number on the ring , but as you know still limited to 1 single or double at each joint.
Even in my very limited experience, that is far from unknown in bungalows with solid floors (and maybe even some multi-storey houses with solid ground floor floors).Ruling out Winstons suggestion of a ring round the loft with no sockets and all sockets spurred off it.
