OP, why not lay a straight edge and level across the bare floorboards above the joists - check from left to right (as in your sketch) and lengthways back across the floor. check in a few positions.
you are looking for a flat level floor esp. above the new lintel - no humps and no slopes.
the sections you have sketched might have originally been shaved on their bottom, bearing edges to allow the joists to sit level on the uneven oak beam?
if the sections have been eased then it means the top edges might all be level?
Not bothered about an uneven floor above as that is what is currently there and goes with the character and age of the property.All I need is that the floorboards are supported by the joists which hopefully touch the steel beam hence the need for packing pieces.
The point is that's how it should be constructed. Just because something has gone without being built properly for years, does not mean that it's correct or should be left like it.
Agree, although my concern was the plastic ones tend to have big cutouts in them meaning the pressure is a fair bit greater. for a heavily loaded beam the bearing would be proved for the whole area of timber being in contact.
However I decided for the ground floor ones there was only 5-6feet so I just went ahead anyway. The floor is that wonky anyway from being 100 years old I wasn't so bothered as long as the rotten bits were replaced!
