EICR Replacement Fuseboard Advice
11 Jun 2013
London
Some of the people here were very helpful in a previous thread and I have decided to replace the following two fuseboards - I am doing this purely to get a EICR report which is fine
The electrican asked me to buy a fuseboard so I would just like to check if the following fuseboard can be replaced with this one please
https://www.screwfix.com/p/british-...d-high-integrity-dual-rcd-consumer-unit/7300g
I know I am going from a 14 way to a 12 way which should be ok right? Is there anything else that you can suggest instead of the above?
What is the reason for replacement? Lack of RCD protection? Or the fact that it's plastic? Neither mandates a replacement as such, but RCD protection will be required if new circuits, extra sockets, etc. are being added.
I would consider the BG board to be a significant downgrade from the Hager in terms of quality.
As far as I'm aware, Hager have never changed their MCB compatibility, so you may be able to buy a metal Hager chassis with RCDs and reuse those MCBs
https://www.consumerunitworld.co.uk/hager-consumer-units-93-c.asp
What do you plan to do with the extra two circuits?
Plus if your electrician is leaving you to source the fuseboard relying on advice from an internet forum, then quite frankly you need a different electrician
The electrician has to design, install, and inspect and test. Part of the design is to decide what is a appropriate for the installation, he measures existing leakage for example and decides if this is likely to cause a problem, including taking into account what equipment is being used.
So part of his job is selecting which consumer unit and what goes in it, when I got the consumer for my house I had to tell the supplier what I wanted it populated with. And I as an electrical engineer got it wrong, I got type B RCBO's and found what the supplier called type B I called curve B, and the scheme member who did the job also missed the error, but I have no redress as my mistake.
So if I can get it wrong what change do you think you have of not making an error.
The BG unit does not comply with electrical regulations so can not be installed. As others have said, you need to find a new electrician who can specify and source all the equipment required to replace your consumer unit.
Is that £150 (incl VAT) for a metal box, a main switch and SPD - or am I missing some 'extras'?
That's full price without any trade discount. Care to post a link of something you'd recommend while quoting mine otherwise the post is a bit meaningless imho.
I was not recommending, or intending to recommend, anything - I was asking a question.
I was merely asking, for my own interest, whether I was right in interpreting the listing as saying that the price quoted was just for the box, main switch and SPD? Is that your interpretation?
