Anyway ….I would be interested in knowing what intruder
alarm siren requires 24v ? Lol
Are you suggesting that the OP got it wrong when he told us ...I think you might find 1 is for a fire alarm which is normal ….and 2 is NOT a siren ….keep going …
It’s only for a burglar alarm external siren which is 24v 0.5a 12w.
Does it use a plug-in adaptor? It would be worth using an FCU rather than a 13A socket if possible, but if the adaptor is integrated with the plug then there's no option for this.
I have tried it with a 1 amp fuse, idea was to stop the MCB tripping should I forget, it did not work, the MCB tripped first. Likely some lighting load but as @JohnW2 said not worth it.
The only problem in fitting a socket what ever size on same circuit as lights is the over load plunges you into darkness, but it does not matter if table and standard lights come from sockets, or other items powered from lights, it is the same problem.
OK- so, as I suggested, it seems that you do share some of winston's concerns?
Ah, apologies, I didn't realise thatOf course, because whenever I go in the loft I like to make a cup of tea.
