Thought she served as a welcome break from the relentless servitude we've been subjected to.
First of all, thank you for pointing out the incorrect use of ferment/foment. We are all still learning.For stirring up hatred the world used is usually fomenting, although fermenting will do. There used to be a poster on here called AngleEyes and he preferrred fermenting over fomenting. As you are a fairly new member you might not have heard of him.
Another character called Scarlet Pimpernel used to ferment also. Here, look:
Freedom of Speech Does Not Include the Right to Offend
Do we know the context within which the teacher displayed the material? If he essentially held up a cartoon to poke fun that's one thing, however if he held up a cartoon to make a debating point or to spark discussion, that's completely different. I understand the cartoon was used in a...www.diynot.com
Your post at no time specifies who you are talking about. That's why I asked.Read the post
Sad beyond comprehension why you'd keep up such a facade.
I see Andy11's supporters accept your theories without the slightest checking of your facts.She's clever though, kept all you boys hard at work during the funeral of Her Majesty, she must have been p155ing herself.
Thanks for the detailed explanation; you have very impressive knowledge of the forum for a new member.First of all, thank you for pointing out the incorrect use of ferment/foment. We are all still learning.
Secondly, I tested your claim that this mistake was also repeated by other users, you're right, it is a common mistake of other users. There's 6 pages of the use of 'ferment' alone, many of them with the incorrect use of the word. Are you seriously suggesting that all these users are the same person?
Then there's 'fermenting' Another 4 pages of the use of the word, one of which is a post from Notch7. Are you seriously expecting the forum to believe that I and Notch7 are the same person because of one common mistake?
So I take your point about the incorrect use of the word, but your claim that it is limited to three people is nonsense.
I think you're scratching for a bit if dirt, and the best you can come up with is the dirt under your fingernails.
Basic Database stuff.Thanks for the detailed explanation; you have very impressive knowledge of the forum for a new member.
And thank you to you also. You demonstrated how you arrive at a conclusion, then you find some data to support your conclusion.
And your friends don't even bother to check your findings, never mind your conclusions.
For future reference there are many methodologies, probably numerous ones on google, that suggest how to progress an investigation.
You started at the wrong end.
Fair Testing is a simple process. It relies on changing a single variable to see how that effects the results.
You failed to change any variable. if you had simply searched on the word, and omitted the user, you would have received different results, and therefore arrived at a different conclusion.
Fair Testing destroyed your theory on the first attempt.
Are you laughing at Andy11's misfortune?
Your counting is inaccurate, therefore your opinion is worthless.I don't see any post from Notch on that list.
But it doesn't matter, the basic principle of Fair Testing destroys andy11's theory. Even if there was only one example of substituting one variable for another and getting a different result proves his theory is fallible to the first test. And that was just one test.Boris Johnson voters have to go the extra mile to excuse him.
I’m not sure the images prove anything, but Johnson has spent years fermenting hatred against the EU, it’s well known he isn’t respected as a leader
i can only comment on what i see and i do not see any post from Notch on that list. And most of those posts refer to the word ferment in a proper context.Your counting is inaccurate, therefore your opinion is worthless.
But you mis-counted because you failed to count all the events that mattered.
there's none so blind as those who will not see.i can only comment on what i see and i do not see any post from Notch on that list. And most of those posts refer to the word ferment in a proper context.
You mean like this, three posts ago?much simpler to post the actual content than a screenshot.
What a bore.
Do what others are doing and don't reply to him oddbod.much simpler to post the actual content than a screenshot.
What a bore.
