My 2000 built is all electric, but has day and night rates.Considering almost all new builds in UK specially flats have no gas supply.
Depends what the heatloss of the room actually is. Bottom line is whatever the heatloss turns out to be you have to input energy to counteract that heatloss. An amount of energy delivered by burning gas will cost around a quarter of the same amount of energy delivered by electricity. Full stop. The end.Doesn't the same applies to electric rads? I mean for 2kw rad for example, it won't be on for the full hour and hence your calculation should give lower cost per hour? The rads will have a thermostat just like room thermostat to control the thing.
How about governments, builders... don't they care when building new homes without gas supply?
Mmm, good point- no idea how well electric panel heaters and water heating score on an EPC. Wouldn't surprise me if they do quite well, wonder how you'd find outCrack on, tell the tenants they will only be able to afford to heat one room in future.
Solid walls, no loft insulation and electric heating and hot water - you might struggle to achieve an EPC "C" and it'll be off the market in a few years.
Electricity is not green. Much of it is generated with gas.That's your opinion, we need green energy.
Never assume that those in charge know what they are talking about.How about governments, builders... don't they care when building new homes without gas supply?
I doubt that even. It would need a COP OF 3.5. Might achieve that in summer when not needed but in winter the COP would be considerably lower.An ASHP in a well insulated new build might be able to heat the property for a similar cost to gas.
A COP of 3.5 is easily achievable, and the point at which the cost of using a heat pump becomes cheaper than gas is a COP of about 3.0, as gas boilers in real installations would be doing very well to be 90% efficient, and the price differential between gas and electricity is 3.3xIt would need a COP OF 3.5.
Mmm, good point- no idea how well electric panel heaters and water heating score on an EPC. Wouldn't surprise me if they do quite well, wonder how you'd find out![]()
I realise that, and that's the difference between him and a landlord like me.Yartin does not want to hear that.
Can anybody tell him what he wants to hear?
