I see what you mean - I thought Murdocat was generalising about any installation, but clearly he meant this specific one."old rubber" in 1977 ?
Maybe he was generalising, but that was not how I interpreted it.I see what you mean - I thought Murdocat was generalising about any installation, but clearly he meant this specific one.
My experience is obviously pretty limited but, at least for the past 40-50 years, I don't recall having seen any rubber cable still in service in domestic installations. However, I've seen plenty of houses (including my present one) which has a fair bit of out-of-service VIR cable still lurking under floorboards and in roof spaces and walls!The latest I have seen rubber cable was in a 1968-built house and even then, it was only on the cooker circuit. I suspect that was the last of that spark's old rubber cable.
No, it just looked like polystyreneAre you certain it is polystyrene and not vermiculite? Take a sample to someone who could verify it for you. A local builder may be able to help.
If there is insulation between your ground floor ceiling and your first floor floor boards, it may be easier, (certainly cheaper), to remove the insulation and allow the warm air from below to help heat the air above.
Definitely not rubber, my colleague who had a good look said it was pvc and the bits he examined were in good condition but that it was 'old colours'Unless it's done in old rubber, then i wouldn't bother testing.
As it would be, until around April 2004.the bits he examined were in good condition but that it was 'old colours'
Maybe, but ...FWIW if it was built in 1977, and has white twin and Earth on the sockets it’s almost certainly 2.5 mm / 1.0 mm
The visible wiring (grey, flattened pvc) ....
There are two types of wire visible around the house, one is grey and the other is green and yellow. I am not sure but i think my colleague said the green and yellow is the bonding that should be upgradedMaybe, but ...
My house was built in 1969, it has pvc cable everywhere that I’ve seenThe latest I have seen rubber cable was in a 1968-built house and even then, it was only on the cooker circuit.
1970 ....Murdoch, the 14th Edition (that the house was wired to) went metric in 1970 or 71 (can't remember which and don't have my regs to hand to confirm) ...
Kind Regards, JohnFOURTEENTH EDITION Issued in 1966.
Reprinted incorporating Amendments, 1968.Reprinted incorporating Amendments, 1969.Supplement on use in metric terms issued, 1969.Amendments issued, 1970.Reprinted in metric units incorporating Amendments, 1970.Reprinted 1972.Reprinted 1973.Amendments issued, 1974.Reprinted incorporating Amendments, 1974.Amendments issued, 1976.Reprinted incorporating Amendments, 1976.
Sorry John I do not agree "anybody saying a rewire is required without doing any testing needs be shown the door".Very good advice. I agree.
