AFAIR, white twin and earth (not LS0H) started appearing in sheds in the 80s.
White around here, Yorkshire, seemed to be what the YEB always used.
True, but a pretty minor 'advantage', given that 115-120V is nowhere near the figure that would be regarded as even remotely 'safe'.If it ever becomes the norm to make earth (c.p.c) full size (as with 1.0 T & E) then at least the touch voltage during a fault might be expected to be 120v (115v if you prefer to think about it so) maximum in practical terms. Which could be an advantage sometimes.
I think many people do. However, as I just wrote, the benefit of (alone) having a 2.5mm² CPC (over 1.5mm²) is minimal, since the 'touch voltage' is then far too high to be 'safe'.When using conduit and wiring sockets with singles, I always used 2.5 for all the conductors.
Going back to the "original" Post, I find it difficult to understand the "Business Practice" of an "Electrician" who would state thatHey all
Money has been tight for some time and the house not properly maintained as a result (my partner has been too sick to work)
However i have had a payrise and got a lot done in the last 3 years, lintels under windows, new fascia and guttering, new bathroom etc.
Next on the list was replacing the old wylex board with a proper consumer unit.
I got an electrician in that i found on google and he took one look and said we will need a complete rewire, he said its the original wiring (house built in 1977). He said the insulation on pvc wiring lasts 25-40 years and its a fire hazard and needs immediate action
The visible wiring (grey, flattened pvc) looks ok to me with no visible damage so i was a bit surprised and asked the electrician from the company i work at to take a look. He is qualified but not able to self notify apparently (not exactly sure what that means)
He said the pvc looks fine, that it is 'old colours' but looks fine, he said that some of the wiring might need replacing but he would expect the majority of it or all of it to be ok. He said pvc doesn't really corrode unless in harsh conditions.
He did say that we should get a consumer unit and 'rcd protection' but said we should just get a condition report done and take it from there and that he would be surprised if we need a complete rewire. He did suggest i get more complete 'electrical bonding' however.
So i have two electricians telling me complete opposites?
Is it really possible for wiring so old to be ok? or is the first electrician correct that i just need to replace it all?
Finding the 7.5k needed to rewire completely would be very tough (i was quoted by the first electrician 7.5k to rewire a 3 bed semi) but the first electrician has scared me a bit.
Finally if i got a condition report and they find problems, they wont stop me using the house electrics will they?
Thanks and sorry for huge post.
Not really an electrical problem, but the leaching of plasticiser isn't exactly going to prolong the life of the cableThe resultant "Goo" was not really an electrical problem - just messy.
At least when dealing with our HSE, di-isoctyl phthalate is considered toxic; contaminated material should be disposed of as controlled waste, and cleaned up, using appropriate PPE.It could be "cleaned up" but replacing such wiring concerned might be considered - for aesthetic reasons only.)
Indeed.Yes John good point and of course enhanced perhaps by the inclusion of a RCD or three on circuits.
Very true. As you will be aware, I'm also a great believer in 'CPC redundancy', and regard that as one of the few 'benefits' of a ring final circuit (L&N 'redundancy' probably being more of a downside than an upside).I go back to the days of the rewireable fuse therefore I have a tendency to favour earthing we can rely on. As I`ve mentioned previously I also favoured joining two or more earths for lighting circuits at some point in each of those circuits in order to add redundancy in case of a thin earthwire being snapped or to bring down the effective R2 value. It all helps and the more of these contributions you can make makes it feel a little bit safer.
Yes, times move o - but I have to say that, if I had a TN installation (which I don't), I wouldn't be particularly uncomfortable with that old situation of reliance on "fusewire and no RCD". I have no figures to support the belief, but I'm sure that people were not 'dying like flies' in those olden days.It`s not really that long ago (well not long ago in my working life anyway) that I was happy for circuit protection to be purely fusewire and not a RCD of some kind in sight. Time moves on and I would not feel as comfortable with that set up today.
"the insulation on pvc wiring lasts 25-40 years and its a fire hazard and needs immediate action."
Old VIR insulation could be deteriorating and become a "fire hazard", but that is most unlikely with PVC insulation.
(There were some problems with PVC Insulation about 30 years ago where some "plasticizers" in the PVC reacted with the copper conductor to produce a "Goo".
Of course, you should have RCD/RCBO protection - on all circuits.
I have booked an electrician to do a condition report next week.
Little concerned at what i will be told as it may take some time to find the funding if i need extensive work but its got to be done at the end of the day. I cant take risks with my grandaughter in the house.
From what i have read on here, if it takes me 1-2 months to fix the actions required (due to finances) on the condition report this doesnt put me in any sort of legal issue?
I would suggest that you try to take a pragmatic approach and 'be optimistic' for the time being, since you may well not need extensive/costly work done. You and we know that you need a new ('modern') CU, but that in itself would probably cost you not much more than, say, a Glastonbury ticket! Beyond that, given that it is 1977 or lter wiring, there may not be a lot that needs to be done.I have booked an electrician to do a condition report next week. Little concerned at what i will be told as it may take some time to find the funding if i need extensive work ....
It's pretty/very unlikley that an EICR will reveal any significant immediate dangers to your granddaughter (or anyone else) - no more than may have existed for the past 3 years or whatever.... but its got to be done at the end of the day. I cant take risks with my grandaughter in the house.
As has been said, there is no legal obligation for a house owner to take any action, ever, as a result of findings of an EICR, per se.From what i have read on here, if it takes me 1-2 months to fix the actions required (due to finances) on the condition report this doesnt put me in any sort of legal issue?
Where exactly in the regs does it say a domestic dwelling needs an AFDD?Your board does require updating with RCD/RCBO protection SP and also AFDD (on sockets) to meet current Regs , RCD in particular if you use electrical equipment outdoors such as a hedge trimmer or lawn mower. It's probably safe in terms of over current protection though.
The house will only need rewiring if during an EICR report faults are found on it e.g. low insulation resistance ( google this to get an understanding).
PVC cable as old as yours doesn't tend to deteriorate unless it's been in contact with polystyrene and cross polymerisation occurs Or it's in direct sunlight when run outdoors.
I would get two more quotes did either complete and tests on any circuits?
