wood cutting circular disk for mini angle grinder wanted
Check on Amazon? I have a metal cutting saw which fits on a small a-g.
Lots of teeth. Goes through wood v quickly. No idea where it came from tho, but they must have existed once. Probably designed for use in a chopsaw which holds the a-g.
  • Two_loggers_on_springboards_with_felling_axes_and_crosscut_saw,_Snohomish_County,_ca_1913_(PI...jpeg
An off-topic post has been removed
I knew the old health and safety card would be through in as the exsuse of if you dont destroy the independent lively hood of your jobs and business in the name of lockdown then we are all doing to die! (shame it was a hoax ay)
The old "health and safety card"? Really? That's very weak
Portable saws require a base plate on which to run - this not only ensures that the workpiece is cut at a constant depth, but also that the user can exert an amount of downwards and forwards pressure to keep the saw cutting in a straight line (although TBH with bigger saws the weight of the saw also helps). Control is also aided by the positioning of the handles and by the fact that the speed a circular saw rotates at is much slower than that of a typical angle grinder, with consequently a much lower peripheral speed
As to your linked disc, have you ever actually used one of them? I actually doubt it. But I have used them in anger on a paying job, and I know that they aren't specifically designed for cutting wood - they are much more for handling composite structures such as cement fibreboard bonded onto OSB, and that the cut quality is pretty horrible on that when seen in comparison to a regular carbide tooth saw blade used in a portable circular sawb cutting OSB alone. Those Bosch blades can also kick back pretty viciously if you over feed them or twist them in the cut (just like a conventional grinding disc will), and they don't last too long on wood, either. In point of fact they are designed much like the segmented discs used to cut stone and metal (on a grinder) i.e. without any teeth and segmented. The cutting action is as a result of carbide grit bonded to the outer edges of the disc abrading its' way through the material much like a grinding wheel would abrade its' way through stone or metal. So they aren't a saw blade at all - but like any other grinding wheel they need to be used with respect.
so it dose not say the tool is unsafe right! but is the blade cutting or grinding
In action it is a grinding wheel - as stated above
Angle grinders are probably one of the more dangerous power tools (and bear in mind that is coming from someone who routinely uses routers, power planers, all sorts of power saws, alligator saws, recip saws, etc for a living) because (I feel) the small size and light weight of the small 4-1/2in and 5in (115 and 125mm) grinders deceives people into thinking they aren't able to do much harm, and that they can get away with a one hand grip (which BTW you shouldn't do with those Bosch discs). The fact that many small angle grinders have lock-on power switches as opposed to paddle switches doesn't help safe usage either. In reality they are responsible for quite a lot of injuries.
As to COVID and your theories on that, please take your comments to a more appropriate place
As to your linked disc, have you ever actually used one of them? I actually doubt it. But I have uzzed them, and I know that they aren't specifically designed for cutting wood - much more for handling composites such as cement fibreboard bonded onto OSB, and the cut quality is pretty horrible on that in comparison to a regular carbide tooth saw blade used in a portable circular saw being used on OSB alone. The Bosch blades can also kick back pretty viciously if you over feed them or twist them in the cut (just like a conventional grinding disc will), and they don't last too long on wood, either. In point of fact they are designed much like the segmented discs used to cut stone and metal (on a grinder) without any teeth. The cutting action is as a result of carbide grit bonded to the outer edges of the disc abrading its' way through the material like a grinding wheel would abrade its' way through stone or metal. So they aren't a saw blade at all - but like any other grinding wheel they need to be used with respect.
No I have not used one; but for cutting wood are they as much use as a metal grinder/ cutting blade?
Kindly read what I wrote again - NO, they are not much use for cutting wood, they cut as rough as a bears arris (because angle grinders have no base plate and therefore the cut cannot be as controlled as it would be on a portable circular saw) AND they are a lot more risky to use because you use them on a grinder, which is inherently more dangerous than a circular saw
