- Joined
- 11 Jan 2004
- Messages
- 46,881
- Reaction score
- 3,986
- Country
Drawn it out now, makes sense. But something is obviously not right with the strappers. Or one of the switches is dicky.
That's my guess as.... Or one of the switches is dicky.
I'd suggest swapping the reds and black over to see if it makes a difference, might just be luckyAll has worked fine for over 10 years.
Never know there may be a join in there somewhere.Drawn it out now, makes sense. But something is obviously not right with the strappers.
OK.View attachment 330074The two way system shown has one wire that passes through the intermediate switch back box but is not connected to the intermediate switch. The two red wires in the one connector seems wrong. However I don't know where the wires go at other end.
Do people really have a problem with how it's wired?
If we ignore L2 on the intermediate and treat it as a connector block then it's simply a very conventionally wired conventional system.
PMartin: I don't know if it's possible to fill this table in.
Can you can please fill the 4 boxes wether the light is 'on' or 'off' for the 4 combinations of the switch positions. If the boxes can't be filled in then describe as 'up up off' etc for the 4 combinations.
TOP SWITCH UP DOWN BOTTOM SWITCH UP DOWN
If I'm reading the diagram correctly, are you saying blue and black both into L1 and leave L3 empty?Just wire it as I said in post #3.
I imagine that as some point a 2 way switch with a loop terminal was used and this intermediate switch was used as a replacement and wired in the same format.Why the original "installer" used a (Relatively Expensive) "Intermediate/Crossover" switch,
in lieu of a SPDT switch
(which would have "done the job" for only a 2-Way [2-Location] switching situation)
is incomprehensible!
Yes.If I'm reading the diagram correctly, are you saying blue and black both into L1 and leave L3 empty?
Lovely thank you.
Thanks again. Before I try those.2 options I thought I'd mention that I also bought a replacement intermediate switch (pic attached). It doesn't follow the L1, L2, L3, L4 layout of the current intermediate so I can't follow the same cable connections. Can it be used?Lovely thank you.
I'm still suspecting a faulty switch and as you have replaced thedimmer with a new switch I'll guess it's the intermediate.
Basically it uses 4 contacts and moving wires around may very well find the faulty contact.
Try swapping the reds and blacks over (as the internal contact at L2 in currently not used) which will work if it's L1 faulty
EFL option may resolve it, if it's L3 's contact faulty
So I'd follow the same layout as the attached switch?Yes it's just the same.
Write your own L1 to L4 on it.
