The vast, vast majority of people who are labelled as anti-vaxxers, have had vaccines and used pharmaceuticals in their life. But instead they are all thrown into one box as quacks who use voodoo instead.
Yes, there are grifters on the anti-Covid vaccine bandwagon but there are in every part of life. Whether pro or against. That doesn't mean you should just accept anyone's view as gospel.
The stats from govts already showed the likelihood of dying from CV-19 was next to nothing. Did the media hype the scare? Absolutely. You're not being honest if you say any different. The same media, years before, exposed how the pharmaceutical companies had tried to get the public into Swine flu shots. Were they cranks then?
The original claim was that the vaccines stopped you getting Covid and you only needed two shots. This then changed to:
- it doesn't stop you getting Covid but stops you passing it on
- It doesn't stop you passing it on either
- You now need 3 shots
- You now need 4 shots
- You now need to continue having shots
I have experience with two relatives who had problems after the vaccine. The NHS didn't even want to know. So any stats out there claiming to take side effects into account is more than questionable.
I will stick my neck out and say most people vaccinated likely won't have issues but a sizeable amount will and it's being underreported. Also, there is no need for these vaccines unless you're in a very small group of people. Even then it's dubious if it has any real benefit for most if at all.
