I would like to install a roof window (Velux or Keylite type). I have read in one of Keylite’s brochure’s that in order to comply with means of escape in the event of a fire, the maximum dimension from the top of the existing ceiling joists in what is currently my loft, to the lowest point on the proposed roof window is 1100mm maximum.
The problem I have is that I have an existing timber purlin which is in the way of where the roof window would need to be positioned. See the sketch below. The purlin is 1180mm (to its top) when measured from the top of the existing ceiling joists.
How do I comply with the means of escape in the event of a fire maximum dimension, without having to alter or relocate the existing timber purlin?
Leaving the purlin untouched, I thought about perhaps installing some 75mm cross battens at 90 degrees to the ceiling joists and then 18mm floorboards or loft boarding on top of those but I am then reducing my head height in the loft which I would eventually want to be turning into a habitable room.
Alternatively, could the purlin be cut either side of the roof window and then the 2 cut ends be supported with timber uprights fitted to the purlin down to the ceiling joists.
I look forward to hopefully receiving any thoughts and/or other suggestions.
