Feel scammed yet
Feel scammed yet
If you followed the conversation properly you would realise the difference between cutting a road thorough 10,000 and a road taking up 10,000
AS you quoted my post it says cutting through tens of thousands
notch was trying to say I said taking up 10s of thousands --- look
1) an 8 mile stretch of a 4 lane highway is about 60 acres, lets say 200 acres for all the additional works etc
so where is the 10,000 acres coming from?
ah so you deliberately used a misleading phrase then when you said "cutting through tens of thousands" -so a bit like the BBC editing the Trump speech.If you followed the conversation properly you would realise the difference between cutting a road thorough 10,000 and a road taking up 10,000
No I was quoting the BBCah so you deliberately used a misleading phrase then when you said "cutting through tens of thousands" -so a bit like the BBC editing the Trump speech.
what you actually meant was cutting down 60 acres
just another example of you seeing an inflammatory headline and not thinking about it
Not sure which is worse - aveatry's grammar, attention span or his math's. I'm also wondering if he's the only one that has been scammed?just another example of you seeing an inflammatory headline and not thinking about it
Here it is from March - I referenced it at the time
Amazon rainforest cut down to build highway for COP climate summit
The infrastructure required to host COP30 in Belém is undermining the cause, campaigners say.www.bbc.co.uk
But they blend their own perspective on the issue.You just couldn't make it up!
you couldnt because its not trueYou just couldn't make it up!
What's the matter with youyou couldnt because its not true
So the BBC are spreading right wing propagandaNo I was quoting the BBC
You are wilfully dishonestWhat's the matter with you
it was an inflammatory and dishonest headlineNo I was quoting the BBC
