And to any "muricans" watching eat your heart out....
United Arab Emirates it seems!
Huh? The writing is in Cyrillic.
Oh, maybe you’ve seen “.ua” somewhere and think .ua is UAE. No, it’s Ukraine.
Translated sales blurb for that device, from https://www.ozon.ru/product/ustroys...napryazheniya-uzm-50ts-uhl4-meandr-589513573/Anybody know what these are?
Protect your equipment from power surges, overloads and network accidents!
The multifunctional protection device UZM-50C UHL4 is a reliable guard for your home and office electronics. The relay protects expensive devices from dangerous voltage drops, impulse interference and overloads, extending their service life and ensuring your peace of mind.
Key advantages of the voltage protection device:
- Comprehensive protection: Against increased (>240-290V) and low (<120-210V) voltage, powerful pulse jumps (>300V) and power overload.
- Powerful and durable: Switches current up to 63A, withstands short-term overloads up to 80A.
- Wide operating range: Works at extremely low (from 30V) and high (up to 440V) voltage.
- Smart monitoring: Tracks and records network parameters (voltage, current, power) in non-volatile memory.
-Protection of settings with a PIN code: No one will be able to change your security settings accidentally or intentionally.
- Gentle start-up: Connects the load at the moment of the voltage transition through zero, reducing starting currents and protecting incandescent lamps and equipment with electric motors.
-Can be used in networks of any configuration; TN-C, TN-S, TN-C-S, TT.
Principle of operation of the surge protection device:
1. Voltage check: When you turn on the device, it first checks the voltage in the outlet.
2. Waiting and counting: If the mains voltage is between the values of the upper Umax and lower Umin of the triggering thresholds specified in the settings, the automatic re-enduation time (APV) begins. At the same time, the indicator shows the time in seconds until the load is connected to the network. In the process of counting the APV time, the "ton" indication periodically appears on the display. If the network voltage does not go beyond the established trigger thresholds before the end of the APV countdown time, the load will be connected to the network at the end of the countdown.
3. Operation and viewing of voltage relay readings:
· After switching on, the device shows the voltage in the network (letter U).
· By pressing the "–" button, you can switch between readings:
· Voltage (U) - volts.
· Current (A) - amperes.
· Power (P) — watts.
· So that you don't forget what exactly the screen shows, a hint appears every 10 seconds (U, A or P)
Technical specifications:
· Rated current: 63 A
· Maximum current (30 min): 80 A
· Surrage protection:
· Adjustable threshold: >240...290 V
· Fixed threshold: >300 V / 20 ms
· Protection against undervoltage:
· Adjustable threshold: <120...210 V
· Fixed threshold: <85 V / 100 ms
· Power limit: 0.5...14.5 kW (configurable)
· Measured current range: 0.6 A...65 A
· Operating voltage: 30 V...440 V
· Body (modules) width: 35 mm (installed on a DIN rail)
· Connection: Front, wires up to 25 mm²
Who is this device for pulse overvoltages?
1. For owners of apartments and houses - to protect the refrigerator, TV, computers, boiler, washing machine and all household appliances.
2. For summer residents - where unstable tension and frequent thunderstorms - is a common thing.
3. For offices and small businesses - for the smooth operation of office equipment, servers and video surveillance systems.
Important! UZM-50C does not replace the circuit breaker (automatic) or RCD, but complements them, providing a higher level of protection.
Attention! If the PIN code is lost, it can only be restored from the manufacturer!
UZM equipment:
· Multifunctional protection device UZM-50C UHL4
· Operating instructions
Make your power grid safe with the UZM-50C UHL4 voltage relay!
Show in full
Trim level
