i have a fire plugged into single socket at back of fire
and the switch at side of fire .
but i want to add a double socket from the single to outside wall
is this possible
Depends on the supply. And where you live. In Wales the garden is still a special location. But start point is to find the feed, is it RCD protected etc.
you might have the option of adding another switch before the fire - fused or unfused - but then that starts to get a bit unwieldy so probably best avoided.
and the block blast online switch at side of fire .
is this possible
Yes, it may be possible, but you should not plug a double socket into a fixed heater/fire outlet unless it's designed for that purpose. Electric fires can draw a lot of power, so adding sockets could overload the circuit.
